1989 Voyager Brake lights, hazard lights and turn signals do not work. The tail lights and license plate lights work.
Checked all the fuses and O.K. I took the steering wheel off to check the turn signal and hazard switch. I pulled the wiring up out of the column to check for broken wires. They all look good. I checked the brake switch and it appears good. I checked the turn signal flasher, but forgot to check the hazard flasher.
Any ideas? I have been trying to follow the wiring diagram out of my Chilton manual, but it does not appear to be totally correct. Thanks in advance for the help.
