Hyd control valve fit
old
I have a MF 185 that has the hyd valves under the seat and want to find out it they will fit on my Ford 841. Sure would be nice to have some more option to run hyd equipment with the 841.
Thanks
They kind of mount the same but the pattern is different. The MF valve ports work a little differently than the correct Ford valve. So I don"t think they will work even if you made an adapter plate.
