Sam from WA
Hey guys, my trusty ol' 89 F150 isn't so trusty anymore, now it shakes really bad in overdrive. It's got the AOD trans in it, and it only shakes when pulling hills and its well warmed up/hot. It will shake on relatively flat ground too, but only after its been warmed up driving around and up a hill (even slight little grades do it). Once warmed up, it won't even move out of its own shadow on the freeway doing about 65-70. It HAS to downshift out of overdrive before the engine will make enough power to accelerate. Before, I could go from about 60 to 75-80 in overdrive no problem whatsoever and not have to downshift. I'm thinking the overdrive band/clutch is going south on me. It still shifts up through all the gears OK and drives fine, even hot, but has problems with overdrive. I can drive in third all the time and have no problems, but it is kinda hard on the fuel economy. Is there something easy I could try first without overhauling the trans? I don't really want to overhaul it if I don't have to
