How much does a back blade weigh ?
Old Roy
Been kicking around an Idea about fabricating an "A" frame to slide into a 2" reciever to put a 3pt hitch on the back of a pickup using electric over hydraulic to raise and lower off the top link.
Front blades are expensive for even a small garden tractor. Back blades can be bought around here than a 42" one for a garden tractor.
A lot will depend on the blade. I have a swing boom on my truck and have loaded a good number of blades and it handled them almost as if they where not there and that was on the 500lbs setting so under 500lbs by a good bit but those are the light duty ones. I do have one that I use on my 841 ford that is probably all of 500 lbs maybe more
