Anonymous-0
A friend has a compressor equipped with a Stanadyne injector pump. It starts readily, runs about 2 seconds and dies. It did this about two years ago and a diesel mechanic questioned if you open the bleed screw on the pump housing, will it run? It then ran. The mechanic said "...remove the pump and bring it to me..." my friend did so and the pump was serviced for $485, after reinstallation, the engine ran well. Now after about two years with approximately 20 hours running time it is doing the same thing. What is likely to be causing this? Any suggestions will be appreciated.
Jim
Jim
