Aaron Ford
I ordered the Pertronix with matching coil from this site and installed it last night. Talk about easy. I made it a little harder by soldering the solderless connectors and heatshrinking the connections. It is amazing. I opened the plug gap to .039 to take advantage of the new coil. It starts on the first crank, needs no choke even when cold, and produces power from a much lower RPM. My electronic tach is also rock steady. I found that my max RPM is 1500 instead of the 2500 that the tach used to bounce to. I need to adjust that. My gear reduction calculations had suggested that I wasn't getting to 2500,, but I had to play it safe. Much less black smoke from the exhaust.
I am aware that this simply fixed problems that I had, but was unaware of. I had new points, condensor and a coil that tested good...
Yeah, it's chrome.
Aaron
Yeah, it's chrome.
Aaron
