4055 15-powershift park slipping
When it rolls ahead does it make a grinding noise? If so you probably have to pull the rockshaft off and both axle housings to put a new park pawl in it. Same thing happened on our 4455. But an adjustment might fix it to.
First check and make sure the park cable is free. Park is spring loaded and if the cable binds or gets stiff,it will only partially engage and give a ratcheting noise. If it is any way stiff,or binds,replace it.
