Kubota hyd capacity
RLS-ia
Hi all, I seen a 8200 Kubota near here worth the money, don"t know much about them. Would it have enough hydraulic flow to run a log splitter? I have a splitter I made that uses a 4 by 24 cylinder.
Thanks
I am guesing it is a small B model like B 8200 If that is the case you would be a little streched on total hyd but IF you got the splitter and tns full you might make it do. Would be easy to find a pto mounted pump and small tank then you could be sure things would work. Where are you located ? Have everything to make the external system cheap.
I'm in SW IA, yes it is a B8200, I'll go check it out tomorrow , I was wanting something to drag firewood-logs out of a timber. This one is already well used so scratches won't matter too much.
My wife's cousin has a B7800 he borrows my splitter, 4 X 24. He says is real slow but will split anything. He is running off the loader valve.
