rotor and distributor cap for I600
Possibly, if you gave the make of your tractor/
engine/machine/ at a parts store they could look
it up.
i am reading it as a standard 600 ihc tractor. all these tractors us the same cap. go to dealer and he will help you thats his job.
Yes it is a allis chalmers I600 Forklift. Need the Delco numbers for a rotor and distributor. Having problems with no spark to plugs. Have spark at points. Could this be the Condenser, rotor or cap?
Napa should have the parts you need. If your not getting spark from the coil wire then it might be points,condenser or coil. Coil wire checks spark before rotor and cap.
Everett
