Clevite bearing help
Well, maybe...1994 Clevite catalog numerical index shows CB-284P as "Case 4, S-SE Series", apparently then available in Std, 10s, 20s and 30's...
No S or SE engine is listed under the Case engine section, nor any under the model section.
An older Fed-Mog catalog shows the S and SE engines as 4's, apparently a 31/2x4 154 cid and a 3.625 (35/8)x4 166 cid, and shows them used in S, SC, SI,SO wheeel tractors, NAP-2 balers and SP9 combines ...HTH
Contact Clevite and see if they know what they fit. Look for std or .010" on the outer shell of the bearing to see if they're standard or undersize. Hal
CB-284M crosses to Michigan 6370 and Case 05709AB. That is what my Michigan interchange books says.
No guarantees.
