buickanddeere
I was half surprised when tossing the little muffin sized factory spec oil filter on the van's 4.3 Chev. For the much longer Wix 51036.
Using the same viscosity oil. Idle pressure is approx 5 psi higher. Pressure at cruise is 60psi, never used to see pressure over 45psi at any time.
Seen some change but not as dramatic with the 6.0L chev when using the larger Wix 51045.
