paramedicchuck
I had the gas tank on my Farmall M cleaned out. The sediment bowl had a filter, but not a gasket. Without a gasket, the sediment bowl leaks the smallest amount of gasoline.
I cut out a new gasket to fit, using cork gasket material. It has helped, but hasn't solved the problem completely. Any ideas on how to make this stop leaking altogether? Better materials to use?
Thanks for any ideas.
