help on Behlen Overdrive
dick orr
New User
Have a 1937 JD model A. Have pretty well restored tractor. Has a Behlen overdrive.some thimes it will engage and that kind of locks transmission up, move shifter around then will unlock. Would like to losk OD in off position but don't know how or how to fix this problem. Any help on how the OD works would help. Thank You. Been through transmission, replaced two gears so know things are ok in transmission { I think] dick
The overdrive shifter rail has a detent that should hold it in either the in or out position. Would guess something going on there. Put one in once in a 37, but sold the tractor years later. Sure would like to locate that tractor back. SN was 462941 on it.
serial number on my 1937 A is 458 410. thanks for you two replys. Do any of you know when OD is locked out. It has sliped in OD twice and run it for awhile, but I would not use the OD , you can't backup with it in OD. Never know that model steers so easy, like it had power steering. Have spent XXXXX dollars , but is very nice tractor. Would like to put picture on thisspot don't know if allowed. Does any one any more about the Behlen over drive. Thanks for your replys. dick
I did not know J D could have belden over drive. or do you mean the high low already in the jd transmission. Clearify me on this Thanks Bill
