chisel plow hp requirement ?
G. Fields
Im looking at going to a chisel plow, and was wondering how many shanks/working width my little Kubota M7040 4wd can comfortably pull. For reference it pulls my 3-16 plow, and 12ft disc with no problems. Thanks for the help.
Rule of the thumb is 10 hp per shank on the chisel.
I've proved this by pulling an 11 shank chisel with a 100 hp tractor and a 13 shank with 130 hp. Both were a good load. I chiseled some ground that had never been chiseled before with a 1086 Farmall and a 13 shank chisel, and it was full throttle, 1st gear all the way, sometimes with the TA pulled back and the front wheels riding about 4" off the ground.
So, about 2.5 chisels for my little 8N... :) Never knew how they figured that, or how difficult it was to pull this type of rig. I seem to learn new things nearly every time I visit here. Thanks!!
twisted shovels also take a little more to pull than spikes. If you can pull 3-16", a 5 or 6 shank chisel is what you should look for.
(quoted from post at 09:49:58 10/09/10) Rule of the thumb is 10 hp per shank on the chisel.
I pulled a 13' chisel behind my 856 (100 horse), but could do it only with dual rear tires. Without the duals, the rear tires just dug two holes in the ground, and we went nowhere. I could pull the chisel in the low side of 3rd or even 4th in corn and bean ground. Dropped the chisel into some sod ground only once. All forward motion ceased, and the front of the tractor was reaching for the sky before I could depress the clutch.
I pulled a 11 shank with an 856. If the ground was loose and chiseled every couple of years, I could run in low 4th.
I would look for a shank if I were you. In our area, a chisel plow is 15 HP/foot minimum. We rent a disc chisel (twisted shovels) every once in a while to pull behind our Oliver 1855 and 7 shanks is all that tractor wants.
Last year we borrowed a neighbors 7 shank sub soiler and dropped it to 5 shanks. Was able to sink it about 18", which would have been well below any plow pan. They pulled 7 shanks with a 150+ HP Magnum. Our 1855 dynoed at 105 a few years ago
That was a heck of a load, and we bent a cheaper cat. 2 top link before borowing their cat 3 top link that would hold up to that amount of pressure. Would do it again in a heart beat though. Dad drove along side of me while I was running it and said the ground was heaving up by the front axel from it.
Donovan from Wisconsin
I pull a 9 shank glencoe with an 8400 Deere MFWD. It has 290 hp stock. Use to have a 1466 with 180 hp that had a hell of a hard time pulling it over 4 mph. I pull 8.5 mph. 9 shanks require at least 200 hp in good going. 2wd drives on it are a joke.
