1935 John Deere AR
I had asked about water in oil and received some great advice but it has lead to another question. Cooling tubes in the head .. I don't see them list as parts or are they called something different ? Are these the tubes around the push rods ? or are they something different. Thanks for the help.
With the two cylinders, and your problem, you are probably dead on target. Use a flashlight, and you probably can see the problem real fast.
AA1615R you need 2 of them. Push rod sleeve. Detwilers also have them. www.detwilertractor.com .Around $25.00
