1958 ford 641 Work Master
Anonymous-0
I have a 1958 641 workmaster and the hydraulics will not lift the bushhog. The hydraulics will raise without a load. I have changed the hydraulic fluid and bleed the line at the hydraulic motor twice.When I bleed the hydraulics, there is flow coming from motor.(piston pump)I also started tractor an looked inside the hydraulic compartment and saw no fluild leaking internally.Could the problem be in the hydraulic cover? If so, where at?
could be the lift piston o-ring...the relief valve...or pump is plain wore out.
also theres a couple pipes in th bottom of resivoir that go from pump manifold to hydraulic controls...i've seen em rust out if tractor isnt serviced regular to keep water out.
