Question How to ADJUST oil pressure John Deere A
DanHoman
New User
I have a 1946 A John Deere. I just had new rings, reground crankshaft, rod bearings etc... In this tractor. According to the gauge at full throttle the oil pressure is only 10 lbs. I prefer it to be a little higher, because I intent to install an oil pressure shutdown switch in the pressure line. I have heard it can be adjusted, can anyone tell me how to adjust the oil pressure?
pull top cover off crank case the auj bolt is in the center of case to the back side there is a clamp bolt cross ways to it lossen it first then turn clock wise
Thanks I appreciate that... In order to keep from trial and error about how much should I turn the adjustment to get about 20 to 25 pounds, if it is only showing 10 pounds now?
(quoted from post at 17:47:13 09/02/10) Thanks I appreciate that... In order to keep from trial and error about how much should I turn the adjustment to get about 20 to 25 pounds, if it is only showing 10 pounds now?
Read your JD service manual again and adjust pressure to Deere's recommended specs. Or you will be sorry.
(quoted from post at 15:56:15 09/02/10)
If he had the service manual, he prolly wouldn't be asking would he? Nice to see the consistancy in your responses.
Dave
(quoted from post at 01:50:23 09/03/10)
If he had the service manual, he probably wouldn't be asking would he? Nice to see the consistency in your responses.
Dave
What is stopping him from purchasing a service manual?
1-800-522-7448
b.t.w. go ahead and run the neutral current through the electrical ground system for all I care.
