Unusual tires on Farmall (DOES ANYONE KNOW)
DanHoman
New User
My friend in Oklahoma just bought an "H" Farmall with unusual tires on the rear. This Farmall has "DUAL" tires, BUT ON A SINGLE RIM. Each rear wheel has TWO tires on it. I have never seen two tires on a single rim, and he says it is factory. He also says this tractor doesn't have hydraulics. So does anyone know what this tractor is?
(quoted from post at 10:40:36 08/26/10) My friend in Oklahoma just bought an "H" Farmall with unusual tires on the rear. This Farmall has "DUAL" tires, BUT ON A SINGLE RIM. Each rear wheel has TWO tires on it. I have never seen two tires on a single rim, and he says it is factory. He also says this tractor doesn't have hydraulics. So does anyone know what this tractor is?
Yes, it is factory. I have never seen that set-up, but it is listed in the Farmall H parts catalog.
DanHoman, That ol H has a set of Sand Duals or aka... "Sandies" They were popular in the old Dust Bowl area of the US. Sure enough Texas/OK Panhandles, SW Kansas. SE Colo. I have seen many sets of them. I will bet that your buddies H has something like 9.5 X 38 or 36s. Not the usual 11 X 38 tire.
That Dual bracket mount is about a 12 in long, 1.5 x 1.5 angle iron with a base bracket welded on each end. There are about 8 brackets/wheel, 16 / tractor. Hope this helps.
Later,
John A.
Hey folks thanks a bunch for the comments and information. I couldn't find anyone who knew what the tires were. I knew I had never seen the dual setup with BOTH tires mounted on the same rim. Thanks again.
