Paint remover
Hi, question for today, some type of paint remover that can be purchased in Canada. I do have a high pressure water spray that does help once a paint remover has been applied. We cannot any longer purchase "lye" in Canada. Cheers, Murray
Can you purchase oven cleaner? I have used that with good results. I just spray it on and let it set for 20 minutes or so and then pressure spray. It takes off grease and old paint well but not so good on newer paint. Be sure to wear protective gear one wouldn't want to get that stuff into the eyes.
my tractor was sprayed over with a spray can at one time. I used some heavy duty oven cleaner and a cheap pressure washer. Cleaned everything and took most of the spray paint and all flakes away.
Dave
Napa has a gasket remover that will work. It is in an aerosol spray. It will also remove powder coating.
