krylancelo
New User
I recently purchased a 9n ford tractor with 6volt generator, front mount distributor, and a 8 volt battery in backwards (neg to ground pos to neg side of positive ground system.) it also had 2 red 12 volt battery cables installed to accommodate the 8 volt battery. I had already replaced the cut out switch that was a chard mess and rewired including the neg starting cable to correct colors and voltage and the correct ground braided strap. The generator only puts out 250 mV directly from turning generator on a bench with ac motor, and test probes attached to the field coil on the side of the housing and the ammeter post. should i see 7.4 volts coming from the generator? or should i replace the unit with a new since the incorrect battery hookup?
