Does anyone know where I can find the correct timing and instructions for setting it on a 56 Int'l tractor. The tractor had a new Injector pump installed, the system seems to be free of air and can be started with ether but then stalls out. I am thinking that the timing may be off on the injector pump as fuel is coming our of each injector - the system was bled. If it doesn't stay running I am thinking the timing may be off - do you think this is the problem? Or could it be another problem with the compression of the tractor? I was not the one who replaced the injector pump so I have never seen it running? Thank you.
