oldrustycars
Working on a Case 1830 skid steer loader. It has a Renault gas engine. It ran very well about 2 months ago, now will not start. Has a good, blue spark as tested with a Briggs and Stratton spark tester. Points look good, and are gapped at .020 per Case. They have been run with a point file, and cleaned. Cap and rotor look good, cleaned with emery paper. 5 psi fuel pressure, gas getting to carb, and filling the bowl. Compression is 150 psi in all 4 cylinders. Plugs are not new, but look ok, cleaned and gapped to .025, according to Case specs. Won"t even sputter when hit with starting fluid. I have new plugs for it, but can"t locate points and condensor. I feel the condensor may be bad, will others interchange? It mounts outside the distributor. Any other ideas? Thanks
