ryanwheelock
Question, I'm working on a 2N and it will kill the battery if the cables are left hooked up. Takes a day or 2 to run it down. What would you recommend I start checking with volt/amp meter to find what is drawing it down. I would post this on the ford forum but I'm NOT a Ford guy and would forget to check there for responses. I know the simple fix it to put a cut-out switch right at the battery terminals but the guy wants to know what is drawing it down. It has a key switch and a push-button solenoid to start it. All so has front lights and a rear taillight (red) and rear work light (like front lights). Just looking for a little guidance on what to check and how-volts/amps????
Thanks
Ryan
Thanks
Ryan
