Tim Adkins
New User
I recently aquired a 1939 Farmall H. It has no serial tag on it where it should be. I wired brushed it down and it doesn't look like there ever was a tag. My first question is, did they not tag some of the early ones? On further investigation I cleaned off the boss on the engine block and the tractor # is FBH636 it is also stamped on the frame rail. Can anybody tell me if the tag could be somewhere else?
(quoted from post at 12:17:50 07/15/10) You havw a prize there as the first one is 501 and early were stamped on the frame.
Correct. The very early Hs did not have a tag. The number was stamped on the frame rail.
I got an old H what i have always thot was an earley one that has a tall oil filter canester and with what looks like started out with steel wheels and switched to rubber...may of been a war model????????,,,,,So my ? IS. is it earley or what???????????????
