ID the tire size on this M
Just saw this picture on the post below and liked the tires on the front. I know this is a Farmall M but wanted to see if you knew what size those fronts are so I could buy a set and put on the front of my H that has a loader. Would the stock rims be wide enough??
I tired to post the picture but had trouble. Look at the post titled "Whew"
Thanks
Ryan
The M in that picture is equipped with heavy duty Schwartz wide front, which uses the heavy duty 6 bolt hubs and stamped steel style of rims. Those hubs rims will not fit on your H. The only way you could put those big tires on an H would be to custom build or modify some rims.
