old
- Location
- Camdenton Missouri
Well not sure what the heck to think of this little truck. Did the fuel pump and it ran real well, then tonight when I was driving home it started to run just like it did before I did the fuel pump. It will not o up to RPMs like it should and will some times die. Exhaust seems to smell like it is hot but is not getting red hot. Thinking maybe the catalytic converter might be plugged up or getting that way. Also seem to run ok till it is good and warmed up then it does not want to run well enough to pull its self. If your lucky when it does mess up if you get the RPMs up and can keep them up it might go but other wise will not pull its self.
So any ideas what might be wrong. 4 cylinder auto, EFI 1993 mighty max
