old
- Location
- Camdenton Missouri
I hope that is. Could not find the mounting plate any where so I tried to solder a new line in and then use rubber hose to hook the two up but the plate was way to dirty to do so and the solder would not stick no matter how well I cleaned it. So I then drilled the holes out a bit more and slid the hose in. Holes where a tad smaller then the hose so as to make a better fit so might help keep water out. I then siliconed around both of those hoses and after is had dried I painted the tank Ford gray, paint I had laying around any how. Has new fuel pump in it and the plan is to install the tank here in just a little bit. Hope this works since no one seems to have the correct parts for it.
