Kevin (FL)
1998 Cherokee, 4L engine. Symptoms: AC clutch "chattering" (but clutch not engaged) when AC turned on. All mechanical components are good. When 12v+ is applied to clutch wire, the clutch engages fine and the system functions properly. Swapped out Siemens AC clutch relay (under hood)with a known good unit, symptoms repeat--a loud "chattering" sound on AC clutch, but no rotation of compressor. System is not fully charged yet; readings 35PSI low side & about 160PSI on high side. Outside temp 78 degrees. Is there a clutch control module that I can replace or is this buried in the PCM? Thanks.
