ryanwheelock
Question about turning at the corners while mowing hay. Seems like most people always come to the end and make a left turn and raise the mower up and make a circle then lower and start cutting again, Is it bad to make a big sweeping turn to the right instead of pullng out and raising the head and circle to the left. If that makes sense. Is it just harder on the U-joints? My problem is my hydraulics have a problem and the head height is stuck at cutting height. If I try to circle around the already cut hay will plug the sickle. But seems like I get chatter in drive line turing either way.
Thanks for the input
Ryan
PS
After 4-5 weeks of rain finally get to cut some last night and then I find a wheel bearing that is bad on the haybine. Wish it would have had a grease fitting on it, it will when it gets repaired.
Ryan
PS
