9n ford exhaust/intake manafolds
The exhaust/ intake manafold is cracked and I need to replace it. Looking at the replacement part in Yesterdays Tractors catatog the replacement part is a two bolt system and mine has four. Is there such a thing as a9n with a four bolt manafold? What can I do? Or does someone know where I can get one. Thanks to all
All the N's have 4 bolts unless there was a oddball. Pretty sure all the manifolds interchange too. Late 8N with side mount MAY be different,but I don't think so.
You can get one right from this site.
Same manifold for all 9N 2N and 8N tractors...no oddballs.
Tim
The only differance in the 8N 9N & 2N mainfolds was the 39 -40 manifolds had a longer neck for the carb mount other than that they are all the same in posted picture you cant see the other two head bolt holes
