old
- Location
- Camdenton Missouri
Well I unloaded that Bob Cat skid steer today. Use the starter to walk it off the trailer, then pulled it most of the way to the shed with my ford 801. I pulled the spark plug just so as to lessen the compression and drag so the starter could put it where I wanted it. Was moving it that way when all at once the engine sounded different. I put my thumb on the plug hole and spun it over and it blew my thumb off. When the day we loaded it up I had filled the cylinder with ATF and it ran out of the carb so I knew the intake valve was stuck open and no compression because of it. Well any how it now runs, has to be on full choke but runs. Guess I'll be rebuild the carb this afternoon
