Covering grass seed
550Doug
Location
Southern Ontario
I've got a 3 acre plot to be rototilled and seeded with a lawn seed mixture. I can co the spreading with a cyclone seeder but was wondering how to cover the seed. obviously i cannot hand rake it so I was thinking about dragging a couple of logging chains with each end tied to each end of a 2 x 4. Any other ideas about how to quickly get some soil over the seed?
Thanks
If you can get hold of a medium weight roller, use the roller and nothing else. If the ground is good and dry take a lot of time to get it nice and flat before seeding. If it's a little damp stay off it until it dries. You're gonna have to live with it for a long time so you had just as well do a smooth job now.
We're going to be seeding around my son's new house soon and I'm going to dread it because the new fill is too damp to do a good job of seed bed prep, but his loan won't go through until the landscaping is done, including the grass seeding. Jim
You can rent a brillion seeder at any rental place.They do a good job of seeding and also
pack the ground.Just dragging things around usually leaves you with bare spots or dragging the seed to the ends where you turn around.
We have found out if you can get some straw it works well as it holds the moisture in so the seed will germinate. Three acres is a large area though. We use small square bales and an old bale bedding chopper that we pull and feed the bales into it.
My favorite covering tool is a heavy oak plank, about 4"x12" with long pole barn spikes driven through to extend about 2 inches below the board. Angle the nails backward in 3 rows with about 3 inch spacing in each row. It is 4 feet wide, same as my lawn roller. I hook a short chain to the plank and pull it in front of my roller. Did a beautiful job on my airstrip... Gene
Wayyyy back when we still row cropped tobacco and had Farmall 140's we would cut a pine pole about 20 ft. long and tie short light weight pieces of pine brush/limbs all along the pole and the pole was tied to the rear cultivator bars. You don't want it heavy. It did a great job and was one heck of a stand of grass when it came up. I did the same in 1999 on some cutover land I couldn't use a cultipacker on and it worked good then too. Cheap to make and works great.
like said below, rent a brillion drill. We have a 6' 3pt, but for 5 acres and up I go rent a 10' pull type. They will get the seed into the soil provided you have a loose seedbed. Before we had a drill, we broadcast and pulled a chain link fence across, worked it in enough, but didn't move too much soil. You can drill when it's windy too.
