4010 Diesel Battery Box mounts
JD4010
New User
I ordered replacement battery boxes & mounting brackets for my JD 4010 from Abilene machine. The back bracket on the right side seems to be wrong. It looks the same as on a 4020 at the JD dealership here in town, but the transmission casting seems to be different on my 4010 than on his 4020. Anyone have any insight?
I'm an IH guy,but I do know that there are several differences between 4010 and 4020 tran cases.Just exactly what and where,I am not sure.Go take a close look at both tractors and you can probably figure it out.
Battery mounts and boxes are different part#s on JDparts.com for 4010 & 4020 which usually means they won't interchange.
AR40209 BOX,BATTERY,RH,WITH CLAMP & ROD for 4020
AR26618 BATTERY BOX, ASSEMBLY,RH for 4010
