Kubota B2320 with mower trouble
I have a 2009, B2320 with a RCK54-29B belly mower. It worked fine all last year and you could raise it and put the pins in to hold the mower up. I put it on this year and when I raise the mower the pin holes are not even close for holding it up. Front link and rear links are right on for adjustment. Any one ever had this problem? My dealer is closed today and is 500 miles away. HELP Please.
Don from Canada
If you did not put the metal clips back in there holder when you removed the mower after its last use and raised the three point up you may have bent the holders Dont ask me how i know. anyway I had to remove the clips and reform them so they would go in the holder. Hope this helps Don.
Alan B.
I think there are 2 adjustable rods that go from the mower to the 3 point. Look in your manual since these have to be at a very correct length. If you get the holes close you can finish with a 2 X 4 by lifting just a little.
I have had 2 different Kubotas with belly mowers and this was always a problem since allignment was never right on. Hence the 2 X 4.
