Ran out of fuel today
Anonymous-0
There is no reason to run out of fuel, but I did it today. No problem I carry a 5 gal can of diesel in my truck. Only problem I didn't have my funnel. I was within 6 mi from home, so I only lost one hour. Had it been in the morning I was about 20 miles from home. Tomorrow is another day. stan
A shotgun will brighten up your day! And keep your tractor's paint bright. Look at that two birds with one stone! (pun definately intended)
Not the only one then and the gauge still said half full. not to mention the to trips it took 1 for fuel. 2 for the air tank to blow the muck out of the line. why when your working on a slope the fuel pick up line need to be on bottom side. Well least the tank got draind after that
A very good friend of mine is somewhat carless and forgetfull. His wife was cutting loose on him, yapping, almost out of control because they were almost out of gas in the pickup heading down the HWY. He reasured her they would be just fine, not to worry. As they crested a hill it died, and sure enough he rolled down the hill in to a small town gas station. Then said ---- see!
Another couple of friends flew to Texas to look at a air boat. The two cousins purchased it and went after it with their pickup. On the way home near Des Moines Iowa they ran out of gas in the pickup. They tried to defuel the air boat and into a pop can etc. So as a last stitch effort, one fired up the air boad, and the outer guy steered the pickup to the next gas station.
They are the most advanced farmers in the area, have a few airplanes, over 9,000 sows, and the biggest Chalenger and field equiupment in our county. We still make them understand deep down, they are red necks...bottom line.
Here is what happened. I have a stick to measure the level. Problem it was calibrated for my MF. which showded I had 5 gal. I should have realized the JD tank was made different. Just not thinking. stan
