REAR AXLE H FARMALL
HOW DO YOU CHECK AXLE GREASE IN A h FARMALL MAYBE 40 SERIES
AND HOW MUCH DOES IT TAKE TO FILL AXLE AND GEAR BOX
HOY MUCH HYDRICAL OIL DOES TH H TAKE IN THE RESOVER
Grease fitting out by the sheel and seal on the tranny there is no lube in the housing sounds like you need a manual bad
Each grease zerk at the outer end of the axle should get 3-4 pumps of the grease gun. The gear lube in the rear end lubes the gears and axle bearings. Check by removing the pipe plug ahead of the clutch pedal and slightly under the clutch rod. Capacity is 6 gallons of 90 weight gear lube. Fill is the large plug near the gear-shift lever on top of the transmission.
the Lift-all (hydraulic system) takes 6 quarts of non-detergent oil. 30 weight works best except in the winter.
You know some are not as smart as thoes who think they are and I did not want spelling and gramar if I had i would have gone to a dictionary and reading why read when you can ask some one who has had experience and wants to show what they know for all the years of working with a h farmall, some people like to help others, course there are those who think they are smarter than anyone else and make good politicians
When buying something like a tractor and you arent familiar with it . Just do yourself a favor and get a manual and read it good then ask questions and you tractor will thank you forever.
When the tires are new and the motor has just been rebuilt and the person is asking 500 for it it does not take to much of smarts to see it is worth this and I don't have a smart person to tell me to buy a manual unless he is in the business of sell ing manuals
