Drawbar removal on JD 4430
Reid1650
I cant get the pin out to move the drawbar forwards and backwards. I push up from the bottom then it just stops. Is there a bolt or pin somewhere to remove???
when it "just stops", lean it over to the left or right and it will come out enough to move the draw bar!
(quoted from post at 23:33:27 05/02/10) when it "just stops", lean it over to the left or right and it will come out enough to move the draw bar!
May I ask "lean what"
There is a pin retainer that one must turn to where the cutout spot in retainer will allow head of drawbar pin to be pushed up enough to free drawbar. Retainer part # is R34253 RETAINER 1 (SUB R96420, A147R, R28040, 19H1732 AND 12H304)
I'm not familiar with JD....
Your manual can help you - you should have a manual. Tractors, combines, & planters - a manual is pretty easy to get & pretty important to have.
Either there is a hairpin retainer at the top of the pin of some sort, which you can just barely get a finger on if you push the pin up, or you need to push the pin up, rotate it 1/4 turn, and let it fall out the bottom - it will have 2 ears on it that fit in slots.
Those are the 2 common ways of other color tractors I have worked with.
--->Paul
