ot, kawiski mule 3010
anyone has 1 of these?
were have a small problem? it runs like chit, and only runs with the choke on, the filter is clean, and the little screen in the carb is been replaced, we know its had bad gas in it and weve replaced it, and running carb cleaner throug it, its a 2006 modal and the sad thing is its only got 600 hrs on it (the ol man just uses it maybe 3 times a month to check cows
Sounds like there is a piece of solid crap in the main jet.teke the carb apart and give it a good cleaning
if it has the brass 'tamper proof' epa carb caps, you can carefully drill though them (barely though them, not into the mixture screw!) and pop them out by prying with said drill bit or a small screwdriver
then you should be able to adjust the carbs as needed.
But by the sounds of it I'd do a full rebuild anyway... even with the 'epa approved' settings it should run halfway decent.
