98 Jeep Laredo
Maybe i should rotate tires from front to Back...? FOR A WHILE and i can't say it has gotten worse Got a rumbling , sound coming from Front end ,, Thought it was hub bearings ,, But No PLAY is Evident ,,, No pulling or change in sound around cuves ,, but seems to have Vibrate static while driving ... 185 ,000 miles... what do you GUYS THINK ? ..
Think you need to put all bearings in front diff after you ck tires by rotating them front to back.david ps hard to ck noises over net
tough diag but just because there's no play doesn't mean the wheel bearing/s aren't the problem. sometimes a trip to the dealer to pay them to figure out what it is is cheaper than throwing parts at it till you get it.
casey in SD
Daughters 99 Olds Cutlass had the same symptons. Replaced the front wheel bearings(hubs). No play, but noisy and vibration. ABS light also came on.
When did the noise start ? All of a sudden ? Tire noise is very common . I had one I had to swap all 4 out till I found it . How many miles on it? Hub bearings can be bad and have no play .
