5 on 5 wheels
What tractors used a 5 on 5" wheel in a 15" size? They sure don't seem too common. I'm looking for a couple for a SC Case. Is there another brand tractor that will fit? I know AC used this size in a 16" on their bigger tractors but I want to go with a 15" wheel. Did the smaller AC's use a 5 on 5" in a 15" size?
TIA
My SC has the heavy castiorn front wheels. My AC RC, Case SO, MH 101 and 44-6, all have 5 bolt 15" front wheels that will fit. They are all light weight steel front wheels. The RC's are 3" wide and I think the MH are wider. I have extra castiorn SC fronts.
I looked in an old "Central Tractor" catalog that has a listing of various tractor wheel size info and could find no 15" wheel with a 5" bolt circle.
As a matter of fact, the A-Cs are the only ones listed with a 5 hole 5" bolt circle wheel and it is 16". The smaller A-Cs used a 5 on 4-1/2 15" wheel. "5 on 5" is the common size for many GM products including 2WD pickups. The center hole size is usually the problem when trying to fit automotive wheels to tractors. Aftermarket painted or chrome wheels seem to many times have the larger center hole. So.....you might want to look for aftermarket GM 15" wheels in your local junkyard.
My '42 SC and 50 DC Cases both had a heavy cast rim for the front.Don't remember the size of either. That was 50 some years ago.
My VC Case has the wheels you want. I'd trade them for a 4:00 x15 Firestone tire as I would like to put the cast wheels I already have on it.
