I've got this Honda motor, it's rare that I have ever had a problem with one. But i am baffled. Heres the deal, it runs for about 45 seconds and shuts off. If you squeze the trigger, it dies right away. So I thought: sticking float needle valve or lack of fuel from tank, obstruction somewhere. But, if you crack the drain screw at the bottom of the carb bowl as soon as it shuts off, it pours fuel out steadily. Just in case , I put a brand new carb off an Identical motor on it, same exact problem. Has fat, blue spark on the ignition test. Any suggestions on where to look next. Air filter is new, I cant figure it out
