mf 50 loader backhoe
mf50
New User
I have a mf50 (9a i25733) needs water pump.
and has leak out of small hole(its a factory drilled hole) in bottom of transmision.any help
thanks chris
Your leak from under the clutch housing is either the rear main seal on the engine or the transmission input shaft seal and requires attention if there's any quantity because it'll soon soak your clutch otherwise. Sam
