MattStiles
New User
I'm totally pulling my hair out today. Unless I've lost my mind, if you push the throttle lever forward the engine speed should increase. It's doing just the opposite. I have a '40 9N and this winter replaced the dash, so I've had that part of the throttle apart. Last fall I put a new throttle lever on when rebuilding the carb, but I'm certain the linkage was working properly after that. When I push the throttle forward the linkage above the exhaust manifold goes up, which rotates the governor linkage clockwise, which pulls the linkage connected to the carburetor towards the front of the tractor. The link to the throttle is mounted on the bottom side of the lever on the carb, so when the throttle lever is moved forwards the lever on the carb moves counterclockwise (when viewed from the right side of the tractor), which closes the throttle? Have I gone insane??? Which part of this is incorrect?
Thank you!
Thank you!
