no hydrolics
pinto
New User
i have no year or model just a plate that reads 2071545,i am looking to restore this tractor and want to get the hydrolic arm moving whare would i find the filter?
The filter is right behind the clutch housing. You cannot get to it unless you femove the slave cylinder from the clutch and then reach through the resevour filler with a long extension and 7/16 flex socket. Be extremely careful not to drop the cap screw that holds the clamp on to the oil slinger. It is not really that hard. Be sure to replace the hydraukic fluid. I use Hy-tran. Work the valve a few times with the motor at a fast idle.The earlier ones were a but easier as the oil resevour was not as deep and dis not need the long extension. Post again if tou have trouble.
