after replacing the axle seals & cleaning the bottom of the axle hausing of dirt ,oil & various pieces of guke in my 37 JD "A" I replaced the rear cover & filled with 140wt oil...in about a week all oil had leaked out on the floor of my shop...after careful inspection I found several small cracks in the bottom of housing...I believe that I can clean these with solvent & then heat with a torch to burn out any left over residue....what liquid or paste can I fill the bottom with that will harden & stop any leaks ?...could probably put about an inch or more in the bottom without getting into anything.....wasn't leaking before repair so I assume dirt & guke had sealed cracks..tractor is not used just part of the family....have another housing but hate to have to change it out....thanks ...Kent
