9n FORD TRACTOR WILL NOT START
Joe TAYLOR
New User
I HAVE PUT NEW PLUGS ,WIRES,COIL,POINTS,CONDENSER,ROTOR CAP,DISTRIBUTOR CAP AND NEW CARBURATOR. TRACTOR WAS RUNNING GREATAND i WAS DOING SOME GRADING.iT SPUTTERED LIKE IT RUN OUT OF GAS AND BACK FIRED AND STOPPED RUNNING.iPUT MORE GAS IN IT AND IT RAN FOR A FEW MINUTES AND STOPPED AGAIN.iHAVE NOT BEEN ABLE TO GET IT STARTED AGAIN. It is still fireing good and has gas in the carburator but seems as if it is not sucking any gas into motor.Any ideas on what the problem could be will be greately appreciated.
Hold your hand over the throat of the carburetor and see if it has any suction while a helper try's to start the engine. Hal
Try the 9n2n&8n forum this site. A lot of knowledgeable people there, too. (also, please use lower case; people think you are shouting).
