super a / fast hitch
pgo12
i see on the helper spring , it attaches to the left side of the torque tube, and the pin goes in the hole on the transmission case, but where does the other end hook to? the rockshaft? thanks,, pg
I have a 140 with a fast hitch, I have a bracket that bolts to the left side of the torque tube and trans case, has a long bolt thru it with a large spring around the bolt. The head part of the bolt is a forked bracket that attaches to the rocker shaft coming out of the hydraulics case.
Have you sent your query to the Farmall page? Many there have Farmall A tractors.
