belarus pto slips
boltcuter
New User
need to find adjustment screws was told they were under 3 poiunt ram with a cover with 4 bolts looked under and saw a 2 bolt cover on left side between tank straps (standing behind tractor)
Don"t know what model you have. 825 cover has 5 bolt. some have a vent as part of cover. under 3pt cyl rod. bolted to top of diff cover.
You have to take the pin out that hooks hyd.cyl. to the 3 pt.lift and shove the cyl. up out of the way.There you will see the cover that has the 5 bolts.Remove the cover and there are 2 band adjustment bolts that have a flat thin head on them.There is a slot on the bottom of the cover that these adjustment bolts nest in so they can't turn when the cover is in place.The pto control linkage has to be locked in neutral to make the adjustment.On the right side of the rear housing where the linkage comes down out of the cab,there is a bolt hole you have to thread a bolt thru the linkage into the housing and this will lock the pto in the neutral position so you can adjust the 2 flat head bolts.
