57 farmall cub
probably needs a ballast resistor
6 volt systems no resistor
12 volt needs a ballast resistor or coil with resistor built in
Ron
check voltage at coil with switch on if less than 9 volts then there is a resistor somewhere in the system.
if 12 volts it will start better but coil won't last
best way is when starter is engaged resistor is bypassed sending 12 volt to coil then resistor is in circuit when tractor is running
Ron
thanks ron & cameron i will check the voltage.i wish i lived in the US because of the price of parts.thanks again.darryl
lot of good info at Farmallcub.com
if you are in Canada, Princess Auto is highly recomended by Candian memebers
good luck
ron
