Anyone ever used Aggrand fertilizer???
JiminIowa
New User
Was wondering if anyone has ever used that Aggrand fertilizer? Seems that the testimonials on their website are good. I have 20 acres of alfalfa hay that I would like to fertilize.
A friend and I were tossing around about two years ago about turning the hay field up side down because the the hay was get less and less,
So we thought lest this, we put NITROGEN down, Now JIM I have never seen my hay field this green and this full of hay, A short 6 acres 3 cutting's real good hay. I can not complain. GOOD LUCK
JR.FRYE
Errr....alfalfa is a legume and as such fixes nitrogen. No need to add more. It will need P and K and some sulfur as that is what is removed when cutting hay. If you had grass, then N would add value as grass is not a legume and does not fix N.
I used a pull behind fore caster, and it depends on how many acres you have, will also depend on the amout of nitrogen you will need, If this is what you want to do I would talk to your FARM SERVICE people, and tell them what you are wanting to do and they would be glad to help you out and tell you what you need and how much. In my casy it worked great; I hope I have answerd your question:
GOOD LUCK:
JR.FRYE
You are right, but my hay field was may be 50/50
Grass and alfalfa and just about as thin as a man going bauld. May I lucky, Who knows.
JR.FRYE
